Giriş
If you determine that your vacuum brush roll will not turn and produces a burning smell, this guide will help you to replace the brush roll.
Neye ihtiyacın var
Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
