Ana içeriğe geç
Eureka AirSpeed Bagless Zuum Brush Roll Replacement
Neye ihtiyacın var
  1. Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: adım 1, 2 resimden 1. Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: adım 1, 2 resimden 2.
    • Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
    • Insure the vacuum is unplugged before starting the process of removing the brush roll.
  2. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
  3. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: adım 3, 2 resimden 1. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: adım 3, 2 resimden 2.
    • Remove the brush cover from the vacuum base, by pulling straight up.
  4. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: adım 4, 1 resimden 1.
    • Firmly press upwards from below the brush roll on the side opposite the belt.
  5. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: adım 5, 1 resimden 1.
    • After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
  6. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: adım 6, 1 resimden 1.
    • Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Celina Burchett
1.122 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-2, Benson Fall 2014 Clemson, Team 2-2, Benson Fall 2014 üyesi
CLEM-BENSON-F14S2G2
4 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
Tami Jones - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 12,028
