Ana içeriğe geç
Giriş
If you determine that your vacuum is no longer picking up debris, this guide will help you to replace a damaged cyclone to increase the suction.
Parçalar
Hiçbir parça belirtilmedi.
  1. Press the grey dust cup release button and gently pull the dust cup towards you. Press the grey dust cup release button and gently pull the dust cup towards you.
    • Press the grey dust cup release button and gently pull the dust cup towards you.
  2. Twist the large, black portion of the cyclone/dust cup to the right to unlock the black cover and cyclone from the clear dust cup.
    • Twist the large, black portion of the cyclone/dust cup to the right to unlock the black cover and cyclone from the clear dust cup.
  3. Twist the clear collar to release the wash screen and small circular collar exposing the cyclone attached to the black head.
    • Twist the clear collar to release the wash screen and small circular collar exposing the cyclone attached to the black head.
  4. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Lift the latch on the top of the black cyclone head to open. You can now see the foam filter inside the cyclone portion of the dust cup.
    • Lift the latch on the top of the black cyclone head to open. You can now see the foam filter inside the cyclone portion of the dust cup.
  6. Remove the white filter by lifting the gray foam filter handle, exposing the screws attaching cyclone to the black head.
    • Remove the white filter by lifting the gray foam filter handle, exposing the screws attaching cyclone to the black head.
  7. Using a T15 Security Torx Screwdriver, remove the 8 screws.
    • Using a T15 Security Torx Screwdriver, remove the 8 screws.
  8. Upon removal of the screws, the cyclone and black head cover will come apart. Upon removal of the screws, the cyclone and black head cover will come apart.
    • Upon removal of the screws, the cyclone and black head cover will come apart.
Sonuç
Celina Burchett
1.101 İtibar
8 adet Kılavuz yazıldı
Takım
Clemson, Team 2-2, Benson Fall 2014 Clemson, Team 2-2, Benson Fall 2014 üyesi
CLEM-BENSON-F14S2G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 18
Her zaman: 994
