Ana içeriğe geç
Eureka EasyClean 71C Bottom Cover Replacement
Neye ihtiyacın var
  1. Eureka EasyClean 71C Bottom Cover Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
  2. Eureka EasyClean 71C Bottom Cover Replacement: adım 2, 1 resimden 1.
    • Pry off the Riser Visor using the plastic opening tool.
  3. Eureka EasyClean 71C Bottom Cover Replacement: adım 3, 1 resimden 1.
    • Remove the screw cap using the metal spudger.
    • First-time removal of the screw cap can be difficult. The screw cap isn’t vital, so don’t worry about damaging the screw cap and just keep trying until it comes out.
  4. Eureka EasyClean 71C Bottom Cover Replacement: adım 4, 2 resimden 1. Eureka EasyClean 71C Bottom Cover Replacement: adım 4, 2 resimden 2.
    • Unscrew the 14mm PH2 Phillips head screw.
    • Pull the bottom cover off of the rest of the casing.
Sonuç
Tanner Durnil
631 İtibar
6 adet Kılavuz yazıldı
Ekip
IUPUI, Team S6-G4, Baechle Fall 2017 IUPUI, Team S6-G4, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S6G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 222
