Ana içeriğe geç
Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly
Neye ihtiyacın var
  1. Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly, Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly: adım 1, 1 resimden 1.
    • Remove the two 10 mm screws from the plastic wire covering using a T5 Torx screwdriver.
    • Remove the covering.
  2. Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly: adım 2, 1 resimden 1.
    • Remove the two 11 mm screws from the white plastic holding the outlet cord in place using a Phillips screwdriver.
  3. Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly: adım 3, 1 resimden 1.
    • Remove the three 20 mm screws from the base of the iron using a Phillips screwdriver.
    • Two screws are beneath the rubber feet and one is in the wire compartment.
  4. Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly: adım 4, 1 resimden 1.
    • Remove the base of the waffle maker to expose the heating conductor and wires.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekli Belgeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 63
