Giriş
The Directional Pad, or D-Pad is the cross-shaped button located on the left side of the faceplate. The directional pad is what allows the user to control their position on the screen and is essential for operation. If it has been damaged or otherwise needs replacement, follow this guide.
Neye ihtiyacın var
Lay the device on a flat surface, with the screen facing the sufrace.
Using angled tweezers, remove the six rubber screw covers from the sockets.
Flip the device so the screen is facing you.
Four hidden retaining clips hold the pieces together even near each corner of the screen.
Insert a Jimmy into the seam located between the faceplate and the shell.
Move the a Jimmy toward the screen until you find the first clasp. Move the handle of the jimmy tool up to pop the faceplate free from the clasp.
Repeat until for each of the four clasps to fully release the faceplate from the shell.
Locate the four circular buttons in a diamond shape on the face plate, the two circular buttons placed next to each other, and the two small oval buttons and a circular button in a row near those in a diamond pattern.
Using angled tweezer, gently remove the buttons from the face plate. The buttons may fall out, so be ready to catch any that fall from the device before intended removal.
Using tweezers, pull the face of the directional pad from its socket in the back piece until the two separate.
