Ana içeriğe geç
ExoPC Slate Back Cover and Shield Replacement
Neye ihtiyacın var
  1. ExoPC Slate Back Cover and Shield Replacement, Back Cover and Shield: adım 1, 2 resimden 1. ExoPC Slate Back Cover and Shield Replacement, Back Cover and Shield: adım 1, 2 resimden 2.
    • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
  2. ExoPC Slate Back Cover and Shield Replacement: adım 2, 2 resimden 1. ExoPC Slate Back Cover and Shield Replacement: adım 2, 2 resimden 2.
    • Using the 00 Phillips screwdriver remove the two screws in the corners.
    • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
    • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
  3. ExoPC Slate Back Cover and Shield Replacement: adım 3, 3 resimden 1. ExoPC Slate Back Cover and Shield Replacement: adım 3, 3 resimden 2. ExoPC Slate Back Cover and Shield Replacement: adım 3, 3 resimden 3.
    • Remove the tape covering the metal shield.
    • Remove the 12 screws using the Phillips #00 screwdriver.
    • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jonathon Cronin
337 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Peak Fall 2018 UMass Dartmouth, Team S2-G1, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 399
