Ana içeriğe geç
ExoPC Slate SSD Replacement
Neye ihtiyacın var
    1. ExoPC Slate SSD Replacement, Back Cover and Shield: adım 1, 2 resimden 1. ExoPC Slate SSD Replacement, Back Cover and Shield: adım 1, 2 resimden 2.
      • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
      FixBot'a Sor
      Yorum Ekle
    2. ExoPC Slate SSD Replacement: adım 2, 2 resimden 1. ExoPC Slate SSD Replacement: adım 2, 2 resimden 2.
      • Using the 00 Phillips screwdriver remove the two screws in the corners.
      • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
      • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
      FixBot'a Sor
      Yorum Ekle
    3. ExoPC Slate SSD Replacement: adım 3, 3 resimden 1. ExoPC Slate SSD Replacement: adım 3, 3 resimden 2. ExoPC Slate SSD Replacement: adım 3, 3 resimden 3.
      • Remove the tape covering the metal shield.
      • Remove the 12 screws using the Phillips #00 screwdriver.
      • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
      FixBot'a Sor
      Yorum Ekle
    1. ExoPC Slate SSD Replacement, SSD: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Remove the two screws using the 0 Phillips screwdriver.
      • Gently pry the SSD from its connector using the tweezers, alternating each side of the SSD until it is free.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jonathon Cronin
337 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Peak Fall 2018 UMass Dartmouth, Team S2-G1, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G1
3 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 57
Her zaman: 883
