Ana içeriğe geç
Explorer One HD Wifi Camera Battery Replacement
Neye ihtiyacın var
  1. Explorer One HD Wifi Camera Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Position the camera with the bottom panel facing up
  2. Explorer One HD Wifi Camera Battery Replacement: adım 2, 1 resimden 1.
    • Use the 000 size Philips screw head
  3. Explorer One HD Wifi Camera Battery Replacement: adım 3, 1 resimden 1.
    • Carefully unscrew the panel
  4. Explorer One HD Wifi Camera Battery Replacement: adım 4, 1 resimden 1.
    • If you need, use the flathead driver to pry off the cover.
    • If not, simply pull off the panel
  5. Explorer One HD Wifi Camera Battery Replacement: adım 5, 1 resimden 1.
    • Once the battery is exposed, simply pull the battery out.
    • You may have to wiggle the battery to pull it out.
  6. Explorer One HD Wifi Camera Battery Replacement: adım 6, 1 resimden 1.
    • The battery is connected the camera by terminals for ease of removal
    • Be sure to keep the battery and camera clean during this step
  7. Explorer One HD Wifi Camera Battery Replacement: adım 7, 1 resimden 1.
    • push the battery back into the housing gently
Sonuç
Now, your camera is as good as new, have fun!
3 farklı kişi bu kılavuzu tamamladı.
Cameron Smith
400 İtibar
2 adet Kılavuz yazıldı
Ekip
Colorado Fixers Colorado Fixers üyesi
Community
1 Üye
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 702
