Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. Extech MN36 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Extech Multimeter MN36 Teardown, Remove protective cover: adım 1, 2 resimden 1. Extech Multimeter MN36 Teardown, Remove protective cover: adım 1, 2 resimden 2.
    • Orange cover provides protection against shocks and better grip
  2. Extech Multimeter MN36 Teardown, Remove back cover: adım 2, 1 resimden 1.
    • Remove two screws to take off back of multimeter
  3. Extech Multimeter MN36 Teardown, Remove fuse and batteries: adım 3, 1 resimden 1.
    • First remove batteries to protect device as you work on it
    • Remove fuse to allow for access to screws
  4. Extech Multimeter MN36 Teardown, Remove circuit board: adım 4, 2 resimden 1. Extech Multimeter MN36 Teardown, Remove circuit board: adım 4, 2 resimden 2.
    • Remove 4 screws
    • Release clips at top of circuit board
    • Remove circuit board
  5. Extech Multimeter MN36 Teardown, Multimeter case: adım 5, 3 resimden 1. Extech Multimeter MN36 Teardown, Multimeter case: adım 5, 3 resimden 2. Extech Multimeter MN36 Teardown, Multimeter case: adım 5, 3 resimden 3.
    • Remove dial
    • Contacts to locate dial position on circuit board
    • Detents to lock in dial position shown removed in last picture
  6. Extech Multimeter MN36 Teardown, Circuit board: adım 6, 2 resimden 1. Extech Multimeter MN36 Teardown, Circuit board: adım 6, 2 resimden 2.
    • Shown circuit board front and rear
Wieli
2.141 İtibar
13 adet Kılavuz yazıldı
1Rehber Yorum
Aneng DT-9205 multimeter does not work properly
ميمي بيبي - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 827
