Ana içeriğe geç
Eyelash Extensions Replacement
Neye ihtiyacın var
    1. Eyelash Extensions Replacement, Eyelash Extensions: adım 1, 1 resimden 1.
      • Wash hands thoroughly and make sure that the station and tools are cleaned and disinfected.
      FixBot'a Sor
      Yorum Ekle
    2. Eyelash Extensions Replacement: adım 2, 1 resimden 1.
      • Place the medical-grade tape under each eye, making sure that all the lower lashes are secured.
      FixBot'a Sor
      Yorum Ekle
    3. Eyelash Extensions Replacement: adım 3, 1 resimden 1.
      • Make sure that the client feels comfortable with the tape on with their eyes closed.
      FixBot'a Sor
      Yorum Ekle
    4. Eyelash Extensions Replacement: adım 4, 1 resimden 1.
      • Brush the eyelashes thoroughly using a mascara wand to remove the eyelashes that are ready to shed.
      FixBot'a Sor
      Yorum Ekle
    5. Eyelash Extensions Replacement: adım 5, 2 resimden 1. Eyelash Extensions Replacement: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Remove all the grown-out lashes using the banana peel method.
      • Hold the natural lash in one clean tweezer and the eyelash extension in the other set of clean tweezers.
      • Gently pull the natural lash and the lash extension in opposite directions and peel the lashes apart like a banana.
      FixBot'a Sor
      Yorum Ekle
    6. Eyelash Extensions Replacement: adım 6, 1 resimden 1.
      • Brush the eyelashes again using a mascara wand after removing all the grown-out lashes.
      FixBot'a Sor
      Yorum Ekle
    7. Eyelash Extensions Replacement: adım 7, 3 resimden 1. Eyelash Extensions Replacement: adım 7, 3 resimden 2. Eyelash Extensions Replacement: adım 7, 3 resimden 3.
      • Put a drop or two of the eyelash primer on the micro swabs.
      • Dab the micro swabs on the eyelashes while making sure that it does not touch the eyelids as it can sting the client’s eyes.
      FixBot'a Sor
      Yorum Ekle
    8. Eyelash Extensions Replacement: adım 8, 1 resimden 1.
      • Let it air dry or use a fan for a faster dry time.
      FixBot'a Sor
      Yorum Ekle
    9. Eyelash Extensions Replacement: adım 9, 1 resimden 1.
      • Place a new lash extension using the eyelash extension adhesive of choice onto the natural eyelash, making sure that the eyelashes are isolated.
      FixBot'a Sor
      Yorum Ekle
    10. Eyelash Extensions Replacement: adım 10, 2 resimden 1. Eyelash Extensions Replacement: adım 10, 2 resimden 2.
      • Repeat Step 9 for both eyes until you are completely satisfied with your work.
      FixBot'a Sor
      Yorum Ekle
    11. Eyelash Extensions Replacement: adım 11, 1 resimden 1.
      • Inspect, separate, and brush the lashes to make sure that there are no upper lashes stuck on the lower lashes.
      FixBot'a Sor
      Yorum Ekle
    12. Eyelash Extensions Replacement: adım 12, 1 resimden 1.
      • Use a fan for 5-10 minutes to make sure that the adhesive is cured.
      FixBot'a Sor
      Yorum Ekle
    13. Eyelash Extensions Replacement: adım 13, 1 resimden 1.
      • Gently remove the tape from under each eye.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
April Pantaleon
349 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 824
