Ana içeriğe geç
Ezonics EZ-307 Main Board and USB Cable Replacement
  1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Get Tools: adım 1, 1 resimden 1.
    • A Phillips Head Size Zero Screw Driver
  2. Ezonics EZ-307 Main Board and USB Cable  Replacement, Detach the Base: adım 2, 1 resimden 1.
    • Using a Phillips-head screwdriver, remove each of the 3 screws from the underside of the camera head.
  3. Ezonics EZ-307 Main Board and USB Cable  Replacement, Set Aside the Base: adım 3, 1 resimden 1.
    • Gently pull back the base and set it aside.
    • Be careful not to pull out the USB cable attachment when taking off the base
  4. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: adım 4, 3 resimden 1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: adım 4, 3 resimden 2. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: adım 4, 3 resimden 3.
    • Gently remove the white connector with the red, green, white & black cord with your fingers. This connector is the end of the USB cable.
  5. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: adım 5, 3 resimden 1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: adım 5, 3 resimden 2. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: adım 5, 3 resimden 3.
    • Press tab on inside of device to release silver ring.
    • Gently remove top (silver) ring of lens casing with your fingers.
  6. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Inner Lens Casing: adım 6, 2 resimden 1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Inner Lens Casing: adım 6, 2 resimden 2.
    • Gently remove inner casing of the lens (silver with a black ring).
    • Be careful not to break the small notch at the top, which holds the inner casing in place.
  7. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove the Inner Ring: adım 7, 2 resimden 1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove the Inner Ring: adım 7, 2 resimden 2.
    • Remove the small, black, ridged inner ring around the lens with your fingers.
  8. Ezonics EZ-307 Main Board and USB Cable  Replacement, Unscrew the Lens: adım 8, 2 resimden 1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Unscrew the Lens: adım 8, 2 resimden 2.
    • Unscrew the lens counterclockwise with your fingers.
  9. Ezonics EZ-307 Main Board and USB Cable  Replacement, Carefully Remove Board From Outer Casing: adım 9, 2 resimden 1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Carefully Remove Board From Outer Casing: adım 9, 2 resimden 2.
    • Turn the hollow outer casing so that you can see inside of it.
    • Gently pull out main board with fingers.
  10. Ezonics EZ-307 Main Board and USB Cable  Replacement, A New Board: adım 10, 2 resimden 1. Ezonics EZ-307 Main Board and USB Cable  Replacement, A New Board: adım 10, 2 resimden 2.
    • Insert your new board into the outer casing. Be sure that it rests firmly between the sets of rails on either side.
  11. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassembly of Lens: adım 11, 2 resimden 1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassembly of Lens: adım 11, 2 resimden 2.
    • Twist the lens piece in clockwise and then insert black ring around the lens.
  12. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: adım 12, 3 resimden 1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: adım 12, 3 resimden 2. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: adım 12, 3 resimden 3.
    • Line up notch on inner lens casing (silver with black ring) with notch on body of camera. Gently push it into place, being sure not to break the notch.
    • Insert the silver ring. You should hear it click into place.
  13. Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: adım 13, 3 resimden 1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: adım 13, 3 resimden 2. Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: adım 13, 3 resimden 3.
    • Hold the camera in one hand with the hollow side facing up.
    • Hold the USB cable in your other hand with the four small holes facing up.
    • Plug the USB cable into the port.
  14. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Base of the Camera: adım 14, 1 resimden 1.
    • Lay the USB cord in the notch at the base of the camera bottom.
    • Place the bottom back onto the camera top.
  15. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Base of the Camera: adım 15, 1 resimden 1.
    • Line up the base of the camera with the screw holes.
    • Use a Phillips-head screwdriver to twist the three screws back into place.
Sonuç
Lyndsi
7 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Mccook Fall 2014 Ohio State, Team 1-5, Mccook Fall 2014 üyesi
OSU-MCCOOK-F14S1G5
4 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 544
