Ana içeriğe geç
FAO Schwarz Apex 1 Front Axle Replacement
Neye ihtiyacın var
  1. FAO Schwarz Apex 1 Front Axle Replacement, Wheel: adım 1, 3 resimden 1. FAO Schwarz Apex 1 Front Axle Replacement, Wheel: adım 1, 3 resimden 2. FAO Schwarz Apex 1 Front Axle Replacement, Wheel: adım 1, 3 resimden 3.
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. FAO Schwarz Apex 1 Front Axle Replacement: adım 2, 1 resimden 1.
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
  3. FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: adım 3, 2 resimden 1. FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: adım 3, 2 resimden 2.
    • Position device upside down so that the screws on the plastic axle pieces can be removed.
    • Use J1 screwdriver bit to remove two 10 mm screws to remove the plastic axle pieces to make access to the telescopic piston easier.
  4. FAO Schwarz Apex 1 Front Axle Replacement: adım 4, 1 resimden 1.
    • Secure a firm grip on the spring and telescopic piston.
    • Pull telescopic piston holding the spring off the device (this may be difficult).
  5. FAO Schwarz Apex 1 Front Axle Replacement: adım 5, 1 resimden 1.
    • Using a tool such as a spudger, gradually maneuver spring off of telescopic piston.
  6. FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: adım 6, 3 resimden 1. FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: adım 6, 3 resimden 2. FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: adım 6, 3 resimden 3.
    • Carefully turn the vehicle over so that the bottom side is facing upward.
    • Using a J1 Screwdriver bit, remove the two 10 mm screws that secure the wheel bearing.
    • Pull the plastic piece that secures the wheel bearing off of the axle.
  7. FAO Schwarz Apex 1 Front Axle Replacement: adım 7, 2 resimden 1. FAO Schwarz Apex 1 Front Axle Replacement: adım 7, 2 resimden 2.
    • Position the axle entirely upright before lifting away from the vehicle.
Sonuç
Carsyn Bernhardt
88 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 268
