Ana içeriğe geç
Fahrenheit FHT 125PRMR Power Cord Replacement
Neye ihtiyacın var
    1. Fahrenheit FHT 125PRMR Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
      • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Fahrenheit FHT 125PRMR Power Cord Replacement: adım 2, 1 resimden 1.
      • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Fahrenheit FHT 125PRMR Power Cord Replacement: adım 3, 2 resimden 1. Fahrenheit FHT 125PRMR Power Cord Replacement: adım 3, 2 resimden 2.
      • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
      • When the pin is removed the two sides of the device can now separate.
      • Be sure to collect the spring that is next to the hinge when they are separated.
      FixBot'a Sor
      Yorum Ekle
    4. Fahrenheit FHT 125PRMR Power Cord Replacement: adım 4, 2 resimden 1. Fahrenheit FHT 125PRMR Power Cord Replacement: adım 4, 2 resimden 2.
      • Use the Phillips Head 1 screwdriver to remove the two screws on the back where the power cable exits the device.
      • Once the two screws are removed; simply lift the case up and off to have access to the power cable.
      FixBot'a Sor
      Yorum Ekle
    5. Fahrenheit FHT 125PRMR Power Cord Replacement: adım 5, 1 resimden 1.
      • To remove the power cable, grab the clear plastic holding and the base of the power cable and pull apart.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Joshua Potts
265 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Harley Fall 2016 IUPUI, Team 2-2, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S2G2
4 Üyeler
4 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where do I find a new power cord? I've tried searching everywhere.
tmbrand04 - Yanıt Paylaş
Where do you buy the power cord?
Dominique - Yanıt Paylaş
probably available at electronic store
john john - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 2,967
