Ana içeriğe geç
Fairphone 1 Midframe Replacement
Neye ihtiyacın var
  1. Fairphone 1 Midframe Replacement, Back Cover: adım 1, 3 resimden 1. Fairphone 1 Midframe Replacement, Back Cover: adım 1, 3 resimden 2. Fairphone 1 Midframe Replacement, Back Cover: adım 1, 3 resimden 3.
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone 1 Midframe Replacement: adım 2, 3 resimden 1. Fairphone 1 Midframe Replacement: adım 2, 3 resimden 2. Fairphone 1 Midframe Replacement: adım 2, 3 resimden 3.
    • Slide the back cover down and remove it from the phone.
  3. Fairphone 1 Midframe Replacement, Battery: adım 3, 3 resimden 1. Fairphone 1 Midframe Replacement, Battery: adım 3, 3 resimden 2. Fairphone 1 Midframe Replacement, Battery: adım 3, 3 resimden 3.
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone 1 Midframe Replacement: adım 4, 1 resimden 1.
    • Remove the battery from your Fairphone.
  5. Fairphone 1 Midframe Replacement, SIM and MicroSD Card: adım 5, 3 resimden 1. Fairphone 1 Midframe Replacement, SIM and MicroSD Card: adım 5, 3 resimden 2. Fairphone 1 Midframe Replacement, SIM and MicroSD Card: adım 5, 3 resimden 3.
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone 1 Midframe Replacement: adım 6, 2 resimden 1. Fairphone 1 Midframe Replacement: adım 6, 2 resimden 2.
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
  7. Fairphone 1 Midframe Replacement, Midframe Assembly: adım 7, 1 resimden 1.
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
  8. Fairphone 1 Midframe Replacement: adım 8, 3 resimden 1. Fairphone 1 Midframe Replacement: adım 8, 3 resimden 2. Fairphone 1 Midframe Replacement: adım 8, 3 resimden 3.
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
  9. Fairphone 1 Midframe Replacement: adım 9, 2 resimden 1. Fairphone 1 Midframe Replacement: adım 9, 2 resimden 2.
    • Carefully round the corner, separating the midframe from the display assembly.
  10. Fairphone 1 Midframe Replacement: adım 10, 1 resimden 1.
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
  11. Fairphone 1 Midframe Replacement: adım 11, 3 resimden 1. Fairphone 1 Midframe Replacement: adım 11, 3 resimden 2. Fairphone 1 Midframe Replacement: adım 11, 3 resimden 3.
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
  12. Fairphone 1 Midframe Replacement: adım 12, 1 resimden 1.
    • Separate any remaining clips and remove the midframe from the phone.
  13. Fairphone 1 Midframe Replacement, Midframe: adım 13, 2 resimden 1. Fairphone 1 Midframe Replacement, Midframe: adım 13, 2 resimden 2.
    • The speakerphone speaker is held to the midframe with some mild adhesive.
    • Use the tip of a spudger to pry the speaker off of the midframe.
  14. Fairphone 1 Midframe Replacement: adım 14, 1 resimden 1.
    • Remove the speaker from the midframe.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
465.759 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 10,939
