Giriş
Restore functionality to your Fairphone after water damage, a nasty fall, or a lightning strike, by replacing your motherboard.
If it’s still possible to do so, save your data to an SD card before disassembling your phone.
Neye ihtiyacın var
With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
Use a fingernail in this indentation to push the battery toward the top of the phone
Pull the battery out away from the phone.
Use your finger to slide the SIM card straight down out of its tray.
Remove the SIM card from your Fairphone.
Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
Use tweezers to remove the volume rocker and power buttons from the display assembly.
Use the flat end of a spudger to disconnect the rear-facing camera cable connector from its socket on the motherboard.
Remove the rear facing camera from the motherboard.
8 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
This is a wonderful and detailed guide - thank you. However, I followed the instructions precisely and whilst the phone now switches on perfectly, the touchscreen does not work. Thoughts on how ifixthat welcome!!
