Ana içeriğe geç
Fairphone 1 Speaker Replacement
Neye ihtiyacın var
  1. Fairphone 1 Speaker Replacement, Back Cover: adım 1, 3 resimden 1. Fairphone 1 Speaker Replacement, Back Cover: adım 1, 3 resimden 2. Fairphone 1 Speaker Replacement, Back Cover: adım 1, 3 resimden 3.
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone 1 Speaker Replacement: adım 2, 3 resimden 1. Fairphone 1 Speaker Replacement: adım 2, 3 resimden 2. Fairphone 1 Speaker Replacement: adım 2, 3 resimden 3.
    • Slide the back cover down and remove it from the phone.
  3. Fairphone 1 Speaker Replacement, Battery: adım 3, 3 resimden 1. Fairphone 1 Speaker Replacement, Battery: adım 3, 3 resimden 2. Fairphone 1 Speaker Replacement, Battery: adım 3, 3 resimden 3.
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone 1 Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the battery from your Fairphone.
  5. Fairphone 1 Speaker Replacement, SIM and MicroSD Card: adım 5, 3 resimden 1. Fairphone 1 Speaker Replacement, SIM and MicroSD Card: adım 5, 3 resimden 2. Fairphone 1 Speaker Replacement, SIM and MicroSD Card: adım 5, 3 resimden 3.
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone 1 Speaker Replacement: adım 6, 2 resimden 1. Fairphone 1 Speaker Replacement: adım 6, 2 resimden 2.
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
  7. Fairphone 1 Speaker Replacement, Midframe Assembly: adım 7, 1 resimden 1.
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
  8. Fairphone 1 Speaker Replacement: adım 8, 3 resimden 1. Fairphone 1 Speaker Replacement: adım 8, 3 resimden 2. Fairphone 1 Speaker Replacement: adım 8, 3 resimden 3.
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
  9. Fairphone 1 Speaker Replacement: adım 9, 2 resimden 1. Fairphone 1 Speaker Replacement: adım 9, 2 resimden 2.
    • Carefully round the corner, separating the midframe from the display assembly.
  10. Fairphone 1 Speaker Replacement: adım 10, 1 resimden 1.
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
  11. Fairphone 1 Speaker Replacement: adım 11, 3 resimden 1. Fairphone 1 Speaker Replacement: adım 11, 3 resimden 2. Fairphone 1 Speaker Replacement: adım 11, 3 resimden 3.
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
  12. Fairphone 1 Speaker Replacement: adım 12, 1 resimden 1.
    • Separate any remaining clips and remove the midframe from the phone.
  13. Fairphone 1 Speaker Replacement, Midframe: adım 13, 2 resimden 1. Fairphone 1 Speaker Replacement, Midframe: adım 13, 2 resimden 2.
    • The speakerphone speaker is held to the midframe with some mild adhesive.
    • Use the tip of a spudger to pry the speaker off of the midframe.
  14. Fairphone 1 Speaker Replacement: adım 14, 1 resimden 1.
    • Remove the speaker from the midframe.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
502.990 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
17.141 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 5,357
