Giriş
Use this guide to replace the Wi-Fi antenna daughterboard in your Fairphone.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
Use a fingernail in this indentation to push the battery toward the top of the phone
Pull the battery out away from the phone.
Use your finger to slide the SIM card straight down out of its tray.
Remove the SIM card from your Fairphone.
Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
Use the flat end of a spudger to disconnect the antenna cable connector.
9 farklı kişi bu kılavuzu tamamladı.
