Giriş
Replacing the battery in your Fairphone 2 is easy and requires no tools.
Neye ihtiyacın var
Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
Pull up the back part of the slim case to separate the small snap fit connections.
Remove the back part of the slim case.
Push the battery toward the top of the phone.
Pull the battery out away from the phone.
10 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
It's not necessary to remove the rim unless you are to do more than just replace the battery.
It would be good to start by saying, “Switch off the phone,” as most owners won't be accustomed to disassembling electronic devices.
