Ana içeriğe geç
Fairphone 2 Battery Replacement
Neye ihtiyacın var
  1. Fairphone 2 Battery Replacement, Slim Case: adım 1, 3 resimden 1. Fairphone 2 Battery Replacement, Slim Case: adım 1, 3 resimden 2. Fairphone 2 Battery Replacement, Slim Case: adım 1, 3 resimden 3.
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
  2. Fairphone 2 Battery Replacement: adım 2, 3 resimden 1. Fairphone 2 Battery Replacement: adım 2, 3 resimden 2. Fairphone 2 Battery Replacement: adım 2, 3 resimden 3.
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
  3. Fairphone 2 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the front part of the slim case.
  4. Fairphone 2 Battery Replacement, Battery: adım 4, 3 resimden 1. Fairphone 2 Battery Replacement, Battery: adım 4, 3 resimden 2. Fairphone 2 Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
    It isn't necessary to remove the rim if all you are doing is changing the battery. That becomes necessary if you are to proceed farther into the phone.
    It might be good to begin by saying switch the phone off. The Fairphone is for everybody and most will have no experience of disassembling electronic devices.
    Jim Kinnibrugh - Yanıt
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
123.755 İtibar
189 adet Kılavuz yazıldı
Ekip
Bir Yorum
It's not necessary to remove the rim unless you are to do more than just replace the battery.
It would be good to start by saying, “Switch off the phone,” as most owners won't be accustomed to disassembling electronic devices.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 11
Son 30 gün: 25
Her zaman: 133,100
