Ana içeriğe geç
Fairphone 2 Headphone Module Replacement
Neye ihtiyacın var
    1. Fairphone 2 Headphone Module Replacement, Slim Case: adım 1, 3 resimden 1. Fairphone 2 Headphone Module Replacement, Slim Case: adım 1, 3 resimden 2. Fairphone 2 Headphone Module Replacement, Slim Case: adım 1, 3 resimden 3.
      • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
      • Pull up the back part of the slim case to separate the small snap fit connections.
      • Remove the back part of the slim case.
      FixBot'a Sor
      Yorum Ekle
    2. Fairphone 2 Headphone Module Replacement: adım 2, 3 resimden 1. Fairphone 2 Headphone Module Replacement: adım 2, 3 resimden 2. Fairphone 2 Headphone Module Replacement: adım 2, 3 resimden 3.
      • Get in between the front part of the slim case and the phone's body with your thumb nail.
      • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
      FixBot'a Sor
      Yorum Ekle
    3. Fairphone 2 Headphone Module Replacement: adım 3, 1 resimden 1.
      • Remove the front part of the slim case.
      FixBot'a Sor
      Yorum Ekle
    1. Fairphone 2 Headphone Module Replacement, Battery: adım 4, 3 resimden 1. Fairphone 2 Headphone Module Replacement, Battery: adım 4, 3 resimden 2. Fairphone 2 Headphone Module Replacement, Battery: adım 4, 3 resimden 3.
      • Push the battery toward the top of the phone.
      • Pull the battery out away from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Fairphone 2 Headphone Module Replacement, Display Assembly: adım 5, 3 resimden 1. Fairphone 2 Headphone Module Replacement, Display Assembly: adım 5, 3 resimden 2. Fairphone 2 Headphone Module Replacement, Display Assembly: adım 5, 3 resimden 3.
      • After taking out the battery you can unlock the display assembly.
      • Flip the two blue switches to the inner position.
      • Slide the display assembly towards the bottom of the phone.
      FixBot'a Sor
      Yorum Ekle
      • Another possible way of sliding the display assembly open.
      FixBot'a Sor
      Yorum Ekle
    2. Fairphone 2 Headphone Module Replacement: adım 7, 1 resimden 1.
      • Take off the display assembly.
      FixBot'a Sor
      Yorum Ekle
    1. Fairphone 2 Headphone Module Replacement, Headphone Module: adım 8, 1 resimden 1.
      • Remove the two Phillips #0 screws of the headphone module marked by the blue circles.
      FixBot'a Sor
      Yorum Ekle
    2. Fairphone 2 Headphone Module Replacement: adım 9, 3 resimden 1. Fairphone 2 Headphone Module Replacement: adım 9, 3 resimden 2. Fairphone 2 Headphone Module Replacement: adım 9, 3 resimden 3.
      • Turn the mainframe around so you're looking at it from the back and can see the two blank parts of the module.
      • Take out the module by first pushing the left part out with your thumb while holding the right side in place.
      • Then push out the right part with your other thumb.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
37 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
134.674 İtibar
189 adet Kılavuz yazıldı
Ekip
10Kılavuz Yorumları
Die beiden Schrauben, die blau gekennzeichnet sind - es sind vier Schrauben. Soweit bin ich jedoch nicht gekommen, da der Bildschirm sich auf beide genannten Weisen nicht abschieben lässt. Schraubstock und leichte Schläge mir einem breiten Schraubenzieher werden keine sinnvollen Werkzeuge sein. Schraubenzieher: Im Baumarkt gibt es keinen PH 0 sondern PH 0 x 60. Der Verkäufer meinte, es müsste der PH 00 x 60 sein; also beide mitgenommen. Zum Testen, welcher der richtige ist, bin ich nicht gekommen, siehe oben. Vielleicht sind auch beide falsch und es gibt per Internet tatsächlich den PH 0. Außerdem muss ich nicht das Kopfhörerteil austauschen, sondern den Lautsprecher, den ich nach Schwierigkeiten inzwischen erhalten habe. Über Lautsprecheraustausch finde ich keine Anleitung. cw@actanol.de
carstenwitt41 - Yanıt Paylaş
Hallo, die zwei blauen Schrauben lösen das Modul vom Rahmen, die beiden anderen sind Torx Schrauben und öffnen das Modul selbst. Das Display sitzt recht fest und muss ein wenig lose gewackelt werden. Eventuell hilft es Gummihandschuhe zu verwenden oder das Fairphone mit der Displayseite auf eine rutschfeste Matte zu legen und dann durch Hin-und Herbewegen zu lockern. Die Anleitung für das Mikrofonmodul zeigt, dass darin auch den Lautsprecher sitzt: Fairphone 2 Microphone Module Replacement
Tobias Isakeit - Yanıt Paylaş
Um einen Fussel aus der Klinkenbuchse zu entfernen, benötigt man zusätzlich zum Philips #0 ,
einen Torx #5 um die beiden kleinen Schrauben zu lösen. Die Metallklammern solten kein Problem darstellen.
Thomas Siegl - Yanıt Paylaş
Nach dem Tausch muss der Näherungssensor (Proximity Sensor) neu kalibriert werden, sonst bleibt das Display beim Telefonieren immer schwarz!
Einstellungen->System->Wartung->Näherungssensor
Florian Steinle - Yanıt Paylaş
Worked flawlessly. Thank you.
So for those of you not speaking english - it can be a good idea to calibrate the proximity sensor after replacing the module (the sensor that blanks (blacks) the screen when holding the phone to your ear).
Settings - Maintenance - Proximity Sensor
johan - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 46
Her zaman: 68,532
