Ana içeriğe geç
Fan Coil Filter Replacement
Neye ihtiyacın var
    1. Fan Coil Filter Replacement, Fan Coil Filter Replacement: adım 1, 1 resimden 1.
      • Clean the fan coil grilles using a paper towel and water.
      • Ensure that the register is thoroughly cleaned out before starting the filter replacement process.
      FixBot'a Sor
      Yorum Ekle
    2. Fan Coil Filter Replacement: adım 2, 1 resimden 1.
      • Close off each adjustable damper.
      • This will ensure that the register grille does not get in the way later on during the filter removal.
      FixBot'a Sor
      Yorum Ekle
    3. Fan Coil Filter Replacement: adım 3, 2 resimden 1. Fan Coil Filter Replacement: adım 3, 2 resimden 2.
      • Remove the screws from fan coil using a Phillips #1 screwdriver.
      • Open up the fan coil.
      FixBot'a Sor
      Yorum Ekle
    4. Fan Coil Filter Replacement: adım 4, 1 resimden 1.
      • Use your hands to remove the filter from the fan coil.
      FixBot'a Sor
      Yorum Ekle
    5. Fan Coil Filter Replacement: adım 5, 2 resimden 1. Fan Coil Filter Replacement: adım 5, 2 resimden 2.
      • Replace the fan coil filter.
      • Make sure to close the fan coil door after the filter replacement is completed.
      FixBot'a Sor
      Yorum Ekle
    6. Fan Coil Filter Replacement: adım 6, 2 resimden 1. Fan Coil Filter Replacement: adım 6, 2 resimden 2.
      • Screw in closed the fan coil door.
      • Open up each of the adjustable dampers for better air flow.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Following these steps, you will be able to replace the filter in your fan coil system.
Abukar Ahmed
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 39
Her zaman: 1,349
