Ana içeriğe geç
Fan Replacement
Neye ihtiyacın var
  1. Fan Replacement, Fan/Heat Sink: adım 1, 1 resimden 1.
    • Remove all the screws that hold the plastic bottom cover on. There are some more screws that cant be seen in the photo.
    FixBot'a Sor
    Yorum Ekle
  2. Fan Replacement: adım 2, 1 resimden 1.
    • Once screws are removed, remove the back cover.
    FixBot'a Sor
    Yorum Ekle
  3. Fan Replacement: adım 3, 1 resimden 1.
    • Encased in red is the area where we are working on
    FixBot'a Sor
    Yorum Ekle
  4. Fan Replacement: adım 4, 2 resimden 1. Fan Replacement: adım 4, 2 resimden 2.
    • Locate the two strips of cables projecting from the fan to the white holders circled in red.
    • Using your hand carefully remove the two strips of cables from the white sockets. Preferably grabbing the strip by the head(the white section where the cables are engulfed). If unable to gingerly pull on the cables.
    • Make care to not rip the connectors and the cables
    FixBot'a Sor
    Yorum Ekle
  5. Fan Replacement: adım 5, 1 resimden 1.
    • Unscrew the four screws surrounding the heat sink.
    FixBot'a Sor
    Yorum Ekle
  6. Fan Replacement: adım 6, 1 resimden 1.
    • You are now clear for liftoff. The fan may fly freely.
    • Now is a prime time to reapply thermal paste if necessary.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eric Martinez
667 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 20-5, Remmell Spring 2017 USF Tampa, Team 20-5, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S20G5
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 54
Her zaman: 969
