Ana içeriğe geç
Farberware FSTO100 Indicator Light Replacement
Neye ihtiyacın var
    1. Farberware FSTO100 Indicator Light Replacement, Indicator Light: adım 1, 1 resimden 1.
      • Make sure toaster is unplugged.
      • Turn toaster upside down so screws on bottom side are facing toward the ceiling and the door is facing towards you.
      FixBot'a Sor
      Yorum Ekle
    2. Farberware FSTO100 Indicator Light Replacement: adım 2, 1 resimden 1.
      • On the left hand side, unscrew the middle screw.
      FixBot'a Sor
      Yorum Ekle
    3. Farberware FSTO100 Indicator Light Replacement: adım 3, 1 resimden 1.
      • Remove the panel on the left hand side. The indicator light is located in the red tube that has wires covered by black tubing coming out.
      FixBot'a Sor
      Yorum Ekle
    4. Farberware FSTO100 Indicator Light Replacement: adım 4, 1 resimden 1.
      • Pull the black wires to remove the indicator light from the red tube.
      FixBot'a Sor
      Yorum Ekle
    5. Farberware FSTO100 Indicator Light Replacement: adım 5, 2 resimden 1. Farberware FSTO100 Indicator Light Replacement: adım 5, 2 resimden 2.
      • Use scissors to cut open cord sheathing and peel back.
      FixBot'a Sor
      Yorum Ekle
    6. Farberware FSTO100 Indicator Light Replacement: adım 6, 1 resimden 1.
      • Use the wire-cutters to remove the light bulb.
      FixBot'a Sor
      Yorum Ekle
    7. Farberware FSTO100 Indicator Light Replacement: adım 7, 2 resimden 1. Farberware FSTO100 Indicator Light Replacement: adım 7, 2 resimden 2.
      • Solder the replacement light bulb back onto its original position.
      FixBot'a Sor
      Yorum Ekle
    8. Farberware FSTO100 Indicator Light Replacement: adım 8, 1 resimden 1.
      • Use electrical tape to reseal the sheathing.
      FixBot'a Sor
      Yorum Ekle
    9. Farberware FSTO100 Indicator Light Replacement: adım 9, 1 resimden 1.
      • Reinsert the indicator light back into the red tube.
      FixBot'a Sor
      Yorum Ekle
    10. Farberware FSTO100 Indicator Light Replacement: adım 10, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    11. Farberware FSTO100 Indicator Light Replacement: adım 11, 1 resimden 1.
      • On the left hand side, screw the middle screw back in.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tony Wang
112 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-35, Regan Fall 2012 Cal Poly, Team 6-35, Regan Fall 2012 üyesi
CPSU-REGAN-F12S6G35
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 1,218
