Ana içeriğe geç
Farberware FSTO100 Power Supply Replacement
Neye ihtiyacın var
    1. Farberware FSTO100 Power Supply Replacement, Power Supply: adım 1, 1 resimden 1.
      • Make sure the toaster is unplugged.
      • First, to remove the plastic bracket, turn toaster oven on its side.
      FixBot'a Sor
      Yorum Ekle
    2. Farberware FSTO100 Power Supply Replacement: adım 2, 1 resimden 1.
      • Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
      FixBot'a Sor
      Yorum Ekle
    3. Farberware FSTO100 Power Supply Replacement: adım 3, 1 resimden 1.
      • Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
      FixBot'a Sor
      Yorum Ekle
    4. Farberware FSTO100 Power Supply Replacement: adım 4, 1 resimden 1.
      • If the wire gets pulled out of the transformer, reinsert it.
      • Use a small flathead screwdriver to secure the screw that holds the wire in place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Tony Wang
112 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-35, Regan Fall 2012 Cal Poly, Team 6-35, Regan Fall 2012 üyesi
CPSU-REGAN-F12S6G35
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 1,810
