Ana içeriğe geç
Fast Fix FOB Battery Replacement
Neye ihtiyacın var
    1. Fast Fix FOB Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Purchase two CR2016 batteries.
      • You can find these at your local drugstore or hardware store.
      FixBot'a Sor
      Yorum Ekle
    2. Fast Fix FOB Battery Replacement: adım 2, 2 resimden 1. Fast Fix FOB Battery Replacement: adım 2, 2 resimden 2.
      • Use a small and thin object, like a penny or other coin, to pry open the FOB. It will separate into two pieces.
      FixBot'a Sor
      Yorum Ekle
    3. Fast Fix FOB Battery Replacement: adım 3, 1 resimden 1.
      • Identify which part of the FOB holds the battery. You should be able to clearly see the circular batteries in one half.
      • You should be able to clearly see the circular batteries in one half. You will not the need the other part of the FOB until the end.
      FixBot'a Sor
      Yorum Ekle
    4. Fast Fix FOB Battery Replacement: adım 4, 2 resimden 1. Fast Fix FOB Battery Replacement: adım 4, 2 resimden 2.
      • Remove both batteries from the FOB by releasing them from the prongs.
      FixBot'a Sor
      Yorum Ekle
    5. Fast Fix FOB Battery Replacement: adım 5, 2 resimden 1. Fast Fix FOB Battery Replacement: adım 5, 2 resimden 2.
      • Insert the new CR2016 batteries with the positive side facing down, and make sure the batteries are secure under the prongs.
      FixBot'a Sor
      Yorum Ekle
    6. Fast Fix FOB Battery Replacement: adım 6, 3 resimden 1. Fast Fix FOB Battery Replacement: adım 6, 3 resimden 2. Fast Fix FOB Battery Replacement: adım 6, 3 resimden 3.
      • Put the FOB back together.
      • You should hear a click that secures the two pieces in place.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 58
Her zaman: 1,087
