Ana içeriğe geç
Fast Fix Repairing/Removing a Violin Chin Rest
Neye ihtiyacın var
  1. Fast Fix Repairing/Removing a Violin Chin Rest, Replacing/removing Violin Chin Rest: adım 1, 1 resimden 1.
    • In this step we gather materials.
    • Some people receive a tiny key for their chin rest when purchasing their violin. It is okay if you do not have one.
    • Paper clip: If you do not have the key a thick paper clip or a thick bobby pin, as used in this guide, will do the job!
    • New Chin Rest: If you're replacing your old one with a new one, please have it ready !
  2. Fast Fix Repairing/Removing a Violin Chin Rest: adım 2, 1 resimden 1.
    • Insert your tool's tip inside a hole in your current violin chin rest attached to your violin
    • Continuously twist your tool in choosen hole towards the left (loosey) or right (tighty)
    • Please make sure to carefully insert your tool's tip and not scratch your instrument by sticking it through the holes too far.
  3. Fast Fix Repairing/Removing a Violin Chin Rest: adım 3, 2 resimden 1. Fast Fix Repairing/Removing a Violin Chin Rest: adım 3, 2 resimden 2.
    • Great Job! If you notice that both the left and right side of your chin rest is screwing off, as shown in the first picture, you're on the right track!
    • It is better to unscrew both sides equally with the chosen tool. The second picture is what you don't want to be doing so that your chin rest does not fall apart when being removed.
  4. Fast Fix Repairing/Removing a Violin Chin Rest: adım 4, 2 resimden 1. Fast Fix Repairing/Removing a Violin Chin Rest: adım 4, 2 resimden 2.
    • If your chin rest does fall apart do not be alarmed!
    • Just remove all the parts from the chinrest on your violin and reattach them as shown.
    • Afterward, simply screw them back in using your chosen tool as shown.
  5. Fast Fix Repairing/Removing a Violin Chin Rest: adım 5, 1 resimden 1.
    • Nice Work! If you have removed your chin rest successfully, there should be wood residue left on your violin and chin rest.
Sonuç
To reassemble your device, follow these instructions in reverse order. (steps 2 and 3)
Dayanna E.
121 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 270
