Ana içeriğe geç
Fast Fix Replacing Fabric on a Folding Screen
Neye ihtiyacın var
  1. Fast Fix Replacing Fabric on a Folding Screen, Folding Screen: adım 1, 1 resimden 1.
    • Lay the screen on a table or some saw horses and roll the fabric onto the screen.
  2. Fast Fix Replacing Fabric on a Folding Screen: adım 2, 1 resimden 1.
    • Using the fabric scissors, cut the fabric to approximately the size of the panel plus a few inches all around for fitting and trimming.
  3. Fast Fix Replacing Fabric on a Folding Screen: adım 3, 2 resimden 1. Fast Fix Replacing Fabric on a Folding Screen: adım 3, 2 resimden 2.
    • Pour a liberal amount of Mod Podge (available at craft and hobby stores, Target, etc.) onto a disposable container, like a plastic lid. Use the sponge roller to begin rolling the Mod Podge onto the old fabric surface.
    • Make sure that you roll the Mod Podge thinly and evenly, otherwise you will have possible bleed-through on your fabric. Work quickly so you cover the whole panel before the Mod Podge begins to dry.
    • Use the foam brush to spread the Mod Podge to the edges of the old fabric panel and into the corners.
  4. Fast Fix Replacing Fabric on a Folding Screen: adım 4, 1 resimden 1.
    • Lay the new fabric onto the panel. Get an assistant to help you position the fabric before you let it contact the Mod Podge.
    • Use the paintbrush to smooth the fabric. Work from one end to the other and from the middle to the sides, smoothing out any wrinkles or bubbles. Work quickly so the Mod Podge does not dry before you are finished smoothing.
Sonuç
After the Mod Podge has dried (overnight suggested), get a helper, stand your folding screen up, unfold it, and enjoy!
John Stewart
119 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 2,564
