Ana içeriğe geç
Fast Fix Screen Replacement
Neye ihtiyacın var
  1. Fast Fix Screen Replacement, Screen: adım 1, 3 resimden 1. Fast Fix Screen Replacement, Screen: adım 1, 3 resimden 2. Fast Fix Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Slide both battery latches to release cover.
    • Remove battery.
  2. Fast Fix Screen Replacement: adım 2, 2 resimden 1. Fast Fix Screen Replacement: adım 2, 2 resimden 2.
    • Remove the M2.5 X 5mm phillips screw for the CD drive.
    • Remove the CD drive.
  3. Fast Fix Screen Replacement: adım 3, 2 resimden 1. Fast Fix Screen Replacement: adım 3, 2 resimden 2.
    • Loosen 2 screws on access door.
    • They cannot be removed
    • Remove the access door.
  4. Fast Fix Screen Replacement: adım 4, 1 resimden 1.
    • Remove 12 M2.5 X 5MM Phillips bottom palm rest screws.
  5. Fast Fix Screen Replacement: adım 5, 3 resimden 1. Fast Fix Screen Replacement: adım 5, 3 resimden 2. Fast Fix Screen Replacement: adım 5, 3 resimden 3.
    • Use a small screwdriver to press in the keyboard latches.
    • Remove the keyboard.
    • Unplug the keyboard cable at the ZIF connection.
  6. Fast Fix Screen Replacement: adım 6, 3 resimden 1. Fast Fix Screen Replacement: adım 6, 3 resimden 2. Fast Fix Screen Replacement: adım 6, 3 resimden 3.
    • Remove the palm-rest cable by releasing the ZIF latch and pulling the wire out.
    • Remove 5 M2.5 X 5mm Phillips and 2 M2 X 3mm Phillips palm-rest screws.
  7. Fast Fix Screen Replacement: adım 7, 1 resimden 1.
    • Use a small flat screwdriver to pry the palm-rest off of the computer.
  8. Fast Fix Screen Replacement: adım 8, 3 resimden 1. Fast Fix Screen Replacement: adım 8, 3 resimden 2. Fast Fix Screen Replacement: adım 8, 3 resimden 3.
    • Remove the wireless antenna
    • Remove the LCD cable
  9. Fast Fix Screen Replacement: adım 9, 1 resimden 1.
    • Remove the 1 M2.5 x 5mm Phillips left hinge screw and 2 M2.5 x 5mm Phillips right hinge screw.
  10. Fast Fix Screen Replacement: adım 10, 1 resimden 1.
    • Pry off the LCD bevel using a small flat screwdriver.
  11. Fast Fix Screen Replacement: adım 11, 1 resimden 1.
    • Remove the 4 M2 X 3mm Philips LCD screws.
  12. Fast Fix Screen Replacement: adım 12, 2 resimden 1. Fast Fix Screen Replacement: adım 12, 2 resimden 2.
    • Unplug the screen cable and remove the screen.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Carl Kangas
182 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
Hello good day, I have a question, I have managed to replace the screen and the computer started the first time without problems, but after I started it again the computer did not turn on the screen again, will you have any possible solution?
vikingo1ero - Yanıt
Hi, Did you ever fix this problem? I'm having the same issue.
Chris Terry -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 3,074
