Ana içeriğe geç
Fast Fix Screen Replacement
Neye ihtiyacın var
    1. Fast Fix Screen Replacement, Screen: adım 1, 3 resimden 1. Fast Fix Screen Replacement, Screen: adım 1, 3 resimden 2. Fast Fix Screen Replacement, Screen: adım 1, 3 resimden 3.
      • Slide both battery latches to release cover.
      • Remove battery.
      FixBot'a Sor
      Yorum Ekle
    2. Fast Fix Screen Replacement: adım 2, 2 resimden 1. Fast Fix Screen Replacement: adım 2, 2 resimden 2.
      • Remove the M2.5 X 5mm phillips screw for the CD drive.
      • Remove the CD drive.
      FixBot'a Sor
      Yorum Ekle
    3. Fast Fix Screen Replacement: adım 3, 2 resimden 1. Fast Fix Screen Replacement: adım 3, 2 resimden 2.
      • Loosen 2 screws on access door.
      • They cannot be removed
      • Remove the access door.
      FixBot'a Sor
      Yorum Ekle
    4. Fast Fix Screen Replacement: adım 4, 1 resimden 1.
      • Remove 12 M2.5 X 5MM Phillips bottom palm rest screws.
      FixBot'a Sor
      Yorum Ekle
    5. Fast Fix Screen Replacement: adım 5, 3 resimden 1. Fast Fix Screen Replacement: adım 5, 3 resimden 2. Fast Fix Screen Replacement: adım 5, 3 resimden 3.
      • Use a small screwdriver to press in the keyboard latches.
      • Remove the keyboard.
      • Unplug the keyboard cable at the ZIF connection.
      FixBot'a Sor
      Yorum Ekle
    6. Fast Fix Screen Replacement: adım 6, 3 resimden 1. Fast Fix Screen Replacement: adım 6, 3 resimden 2. Fast Fix Screen Replacement: adım 6, 3 resimden 3.
      • Remove the palm-rest cable by releasing the ZIF latch and pulling the wire out.
      • Remove 5 M2.5 X 5mm Phillips and 2 M2 X 3mm Phillips palm-rest screws.
      FixBot'a Sor
      Yorum Ekle
    7. Fast Fix Screen Replacement: adım 7, 1 resimden 1.
      • Use a small flat screwdriver to pry the palm-rest off of the computer.
      FixBot'a Sor
      Yorum Ekle
    8. Fast Fix Screen Replacement: adım 8, 3 resimden 1. Fast Fix Screen Replacement: adım 8, 3 resimden 2. Fast Fix Screen Replacement: adım 8, 3 resimden 3.
      • Remove the wireless antenna
      • Remove the LCD cable
      FixBot'a Sor
      Yorum Ekle
    9. Fast Fix Screen Replacement: adım 9, 1 resimden 1.
      • Remove the 1 M2.5 x 5mm Phillips left hinge screw and 2 M2.5 x 5mm Phillips right hinge screw.
      FixBot'a Sor
      Yorum Ekle
    10. Fast Fix Screen Replacement: adım 10, 1 resimden 1.
      • Pry off the LCD bevel using a small flat screwdriver.
      FixBot'a Sor
      Yorum Ekle
    11. Fast Fix Screen Replacement: adım 11, 1 resimden 1.
      • Remove the 4 M2 X 3mm Philips LCD screws.
      FixBot'a Sor
      Yorum Ekle
    12. Fast Fix Screen Replacement: adım 12, 2 resimden 1. Fast Fix Screen Replacement: adım 12, 2 resimden 2.
      • Unplug the screen cable and remove the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Carl Kangas
236 İtibar
1 Kılavuz yazıldı
Ekip
Michigan Tech, Team S3-G8, Galliah Fall 2017 Michigan Tech, Team S3-G8, Galliah Fall 2017 üyesi
MTU-GALLIAH-F17S3G8
1 Üye
12 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hello good day, I have a question, I have managed to replace the screen and the computer started the first time without problems, but after I started it again the computer did not turn on the screen again, will you have any possible solution?
vikingo1ero - Yanıt Paylaş
Hi, Did you ever fix this problem? I'm having the same issue.
Chris Terry - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 23
Son 30 gün: 109
Her zaman: 3,857
