Ana içeriğe geç
Fast Fix Shower Curtain Permanent Rod Replacement
Neye ihtiyacın var
  1. Fast Fix Shower Curtain Permanent Rod Replacement, Shower Curtain Permanent Rod Replacement: adım 1, 1 resimden 1.
    • Use a measuring tape to measure the length of the rod in order to make sure the replacement is the same length.
  2. Fast Fix Shower Curtain Permanent Rod Replacement: adım 2, 2 resimden 1. Fast Fix Shower Curtain Permanent Rod Replacement: adım 2, 2 resimden 2.
    • Using your flathead screwdriver or your screwdriver gun, loosen the screw by turning it counterclockwise.
  3. Fast Fix Shower Curtain Permanent Rod Replacement: adım 3, 1 resimden 1.
    • Remove the old rod as well as the brackets.
  4. Fast Fix Shower Curtain Permanent Rod Replacement: adım 4, 1 resimden 1.
    • Use disinfecting wipes to clean the area on the wall where the old brackets were.
  5. Fast Fix Shower Curtain Permanent Rod Replacement: adım 5, 1 resimden 1.
    • Grab your new shower curtain rod.
    • If preferred, hold your old shower curtain rod against your new one to make sure they are both the same size.
  6. Fast Fix Shower Curtain Permanent Rod Replacement: adım 6, 2 resimden 1. Fast Fix Shower Curtain Permanent Rod Replacement: adım 6, 2 resimden 2.
    • Lastly, using your flat head screwdriver or screwdriver gun, rotate the screw clockwise to tighten the screw.
Sonuç
To reassemble your device, follow these instructions in reverse order
2 farklı kişi bu kılavuzu tamamladı.
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 802
