Ana içeriğe geç
Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement
Neye ihtiyacın var
  1. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement, Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 1, 2 resimden 1. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement, Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 1, 2 resimden 2.
    • Be sure to disconnect the dryer from its power source prior to starting the replacement process.
    • Open the Dryer Door.
  2. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 2, 2 resimden 1. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 2, 2 resimden 2.
    • Take the pliers and clamp onto the strike.
    • Push it from one side and then lift it out on the other side.
  3. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 3, 1 resimden 1.
    • Compare the old strike to the new ones that come in the kit to see which one will go into our dryer.
    • Make sure the new strike has all of the same fittings as the old strike.
  4. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 4, 3 resimden 1. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 4, 3 resimden 2. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 4, 3 resimden 3.
    • Take the new strike and set it into position.
    • Using a bottle nose pliers, push on one side of the strike until it's in place.
    • Using your hand, push the strike into place.
  5. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 5, 3 resimden 1. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 5, 3 resimden 2. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 5, 3 resimden 3.
    • Next, we'll replace the catch.
    • Remove the screws that are holding the inside of the door to the outside panel.
    • Once both screws are removed, you now have access to the back of the door catch.
  6. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 6, 3 resimden 1. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 6, 3 resimden 2. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 6, 3 resimden 3.
    • Take the pliers and push out the top of the door catch.
    • Now, take the pliers and push out the bottom of the catch.
    • Take the pliers and squeeze the metal clip, then push the catch all the way through.
  7. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 7, 1 resimden 1.
    • Take the new catch and place it into the original opening where we removed the old catch.
  8. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 8, 3 resimden 1. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 8, 3 resimden 2. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: adım 8, 3 resimden 3.
    • Replace the screws that were removed and put the door back together.
    • After confirming the door shuts properly, reconnect the dryer to its power source and test out the dryer to ensure the door remains closed while in operation.
    • If the door remains closed during the test run, the repair is done.
Sonuç
Bir başkası bu kılavuzu tamamladı.
BizzzyBeee
184 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 51
Her zaman: 458
