Giriş
This guide shows how to replace the main power cord in the Fellowes T7CM.
Neye ihtiyacın var
Check to make sure the shredder is not plugged in to any electrical outlet.
Remove the shredder from the catch basket and place the silver side down on a flat surface.
Place the catch basket aside as you will not be needing it for the rest of the disassembly.
Flip the shredder silver side down and place on a flat even surface.
Remove the manufacturer's label in order to gain access to the hidden screw hole.
Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
Remove the wire holder. This is a small screwed in piece of plastic which holds the wires in place. The screw length is 10 mm and the head diameter is 6 mm.
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Great instructions. Only question is what type of cord/plug to purchase? If found this on Amazon, but not sure if it’s correct.
GE 4306-31W5, Black, Household, DIY Repair, Replacement Plug Fix, Ideal for Lamps, TVs and Small Appliances, Indoor Rated, UL Listed, 54268,
