Ana içeriğe geç
Fellowes T7CM On, Off, Reverse Switch Replacement
Neye ihtiyacın var
  1. Fellowes T7CM On,  Off, Reverse Switch Replacement, Fellowes T7CM Casing and Trigger Replacement: adım 1, 1 resimden 1.
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
    FixBot'a Sor
    Yorum Ekle
  2. Fellowes T7CM On,  Off, Reverse Switch Replacement: adım 2, 1 resimden 1.
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
    FixBot'a Sor
    Yorum Ekle
  3. Fellowes T7CM On,  Off, Reverse Switch Replacement: adım 3, 1 resimden 1.
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
    FixBot'a Sor
    Yorum Ekle
  4. Fellowes T7CM On,  Off, Reverse Switch Replacement: adım 4, 1 resimden 1.
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
    FixBot'a Sor
    Yorum Ekle
  5. Fellowes T7CM On,  Off, Reverse Switch Replacement, On,  Off, Reverse Switch: adım 5, 1 resimden 1.
    • Unscrew both of the screws from the circuit board of the switch . Lift the circuit board away from the device. The screw length is 10 mm and the head diameter is 6 mm.
    FixBot'a Sor
    Yorum Ekle
  6. Fellowes T7CM On,  Off, Reverse Switch Replacement: adım 6, 2 resimden 1. Fellowes T7CM On,  Off, Reverse Switch Replacement: adım 6, 2 resimden 2.
    • Remove the plastic switch case.
    • After the plastic case is removed, the switch can be replaced.
    • During the switch replacement, be careful of the springs that are held in side. They can potentially come loose and get lost.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Michael Aldrich
686 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S2G2
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 66
Her zaman: 4,462
