Ana içeriğe geç
Felt Z85 Brake Pad Replacement
Neye ihtiyacın var
  1. Felt Z85 Brake Pad Replacement, Remove Wheel: adım 1, 3 resimden 1. Felt Z85 Brake Pad Replacement, Remove Wheel: adım 1, 3 resimden 2. Felt Z85 Brake Pad Replacement, Remove Wheel: adım 1, 3 resimden 3.
    • Pull up on brake-release lever to spread pads for easy access.
    • Release lever on the right side of the wheel.
    • Loosen left nut on wheel until wheel comes free.
  2. Felt Z85 Brake Pad Replacement, Remove Pad(s): adım 2, 3 resimden 1. Felt Z85 Brake Pad Replacement, Remove Pad(s): adım 2, 3 resimden 2. Felt Z85 Brake Pad Replacement, Remove Pad(s): adım 2, 3 resimden 3.
    • Locate Brake Caliper.
    • Use 4.0 mm allen key to remove main bolt.
    • Rotate counterclockwise to loosen.
    • Be careful not to lose both the washer and spacer found in-between the bolt and the brake pad mounting hole.
    • Repeat step 2 to remove the pad on the other side.
  3. Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): adım 3, 2 resimden 1. Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): adım 3, 2 resimden 2.
    • Brake Pad: The item being replaced.
    • Spacer: This item will be reused.
    • Washer: This item will be reused.
    • 4 mm hex bolt.
    • Note order of mounting hardware for reinstall.
Sonuç
Ryan Marschall
123 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-21, Donnelly Fall 2014 USF Tampa, Team 1-21, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G21
1 Üye
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 1,067
