Ana içeriğe geç
Fender Frontman 15r Fuse Replacement
Neye ihtiyacın var
  1. Fender Frontman 15r Fuse Replacement, Fuse: adım 1, 3 resimden 1. Fender Frontman 15r Fuse Replacement, Fuse: adım 1, 3 resimden 2. Fender Frontman 15r Fuse Replacement, Fuse: adım 1, 3 resimden 3.
    • Be sure to unplug the device before proceeding.
    • Insert any tool with a small, flat end (such as a spudger, flathead screwdriver or plastic opening tool) into the groove in the bottom of the power input and wedge the plastic slot out from the amp.
    • There will be two compartments (one enclosed, one exposed) each containing a fuse. The exposed fuse is the active fuse and the enclosed one is a spare.
    FixBot'a Sor
    Yorum Ekle
  2. Fender Frontman 15r Fuse Replacement: adım 2, 2 resimden 1. Fender Frontman 15r Fuse Replacement: adım 2, 2 resimden 2.
    • Remove the blown exposed fuse and replace it with the enclosed fuse. If there is not an extra enclosed fuse, a new fuse must be ordered and inserted into the exposed slot.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephen Figueira
151 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-30, Regan Fall 2012 Cal Poly, Team 24-30, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G30
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 79
Her zaman: 14,765
