Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Neye ihtiyacın var
Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
Mark, make note of, or remember the arrangement of the wires.
Remove the four female disconnected terminals from the switch terminals.
Once the old power switch is removed, install the new one by following the guide in reverse.
Bir başkası bu kılavuzu tamamladı.
