Ana içeriğe geç
Fender Jazz Bass Strings Replacement
Neye ihtiyacın var
  1. Fender Jazz Bass Strings Replacement, Strings: adım 1, 1 resimden 1.
    • Loosen the strings by turning the tuning pegs.
  2. Fender Jazz Bass Strings Replacement: adım 2, 1 resimden 1.
    • Once the strings are loose, remove them from the tuning pegs.
    • If you prefer, you can also cut the strings off.
  3. Fender Jazz Bass Strings Replacement: adım 3, 2 resimden 1. Fender Jazz Bass Strings Replacement: adım 3, 2 resimden 2.
    • Reach under the bridge to pull out the end of each string.
  4. Fender Jazz Bass Strings Replacement: adım 4, 2 resimden 1. Fender Jazz Bass Strings Replacement: adım 4, 2 resimden 2.
    • Insert the end of the string with no knob on the bottom through the bridge first.
    • Pull each string through to the top of the neck.
  5. Fender Jazz Bass Strings Replacement: adım 5, 1 resimden 1.
    • Insert the strings into the indentations on the nut.
    • Wrap the strings around the tuning pegs about two times.
  6. Fender Jazz Bass Strings Replacement: adım 6, 2 resimden 1. Fender Jazz Bass Strings Replacement: adım 6, 2 resimden 2.
    • Tighten the tuning pegs until the bass is in tune.
    • The standard tuning for a bass is E A D G.
    • You will have excess string hanging off the pegs of the bass.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Matthew Caldera
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 654
