Ana içeriğe geç
Fender Starcaster Bridge Replacement
Neye ihtiyacın var
    1. Fender Starcaster Bridge Replacement, Loosen the Strings: adım 1, 3 resimden 1. Fender Starcaster Bridge Replacement, Loosen the Strings: adım 1, 3 resimden 2. Fender Starcaster Bridge Replacement, Loosen the Strings: adım 1, 3 resimden 3.
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
      FixBot'a Sor
      Yorum Ekle
    2. Fender Starcaster Bridge Replacement, Remove the Strings from the Tuning Pegs: adım 2, 2 resimden 1. Fender Starcaster Bridge Replacement, Remove the Strings from the Tuning Pegs: adım 2, 2 resimden 2.
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
      FixBot'a Sor
      Yorum Ekle
    3. Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: adım 3, 3 resimden 1. Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: adım 3, 3 resimden 2. Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: adım 3, 3 resimden 3.
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
      FixBot'a Sor
      Yorum Ekle
    1. Fender Starcaster Bridge Replacement, Bridge: adım 4, 2 resimden 1. Fender Starcaster Bridge Replacement, Bridge: adım 4, 2 resimden 2.
      • On the back of the guitar, remove the plate covering the spring cavity. In the spring cavity, reduce the tension on the bridge springs by first loosening the retainer screws a bit.
      FixBot'a Sor
      Yorum Ekle
    2. Fender Starcaster Bridge Replacement: adım 5, 3 resimden 1. Fender Starcaster Bridge Replacement: adım 5, 3 resimden 2. Fender Starcaster Bridge Replacement: adım 5, 3 resimden 3.
      • To remove the springs from the bridge, grip the end with pliers and pull up.
      • It is safe to use the body of the guitar for leverage.
      FixBot'a Sor
      Yorum Ekle
    3. Fender Starcaster Bridge Replacement: adım 6, 3 resimden 1. Fender Starcaster Bridge Replacement: adım 6, 3 resimden 2. Fender Starcaster Bridge Replacement: adım 6, 3 resimden 3.
      • Be aware that the ground wire for the electronics of the guitar is routed through the body and soldered to the spring retainer.
      FixBot'a Sor
      Yorum Ekle
    4. Fender Starcaster Bridge Replacement: adım 7, 3 resimden 1. Fender Starcaster Bridge Replacement: adım 7, 3 resimden 2. Fender Starcaster Bridge Replacement: adım 7, 3 resimden 3.
      • Remove the screws from the front of the bridge.
      • It may be helpful to only loosen the outer screws as you remove the inner screws, in order to prevent damage to the guitar.
      FixBot'a Sor
      Yorum Ekle
    5. Fender Starcaster Bridge Replacement: adım 8, 1 resimden 1.
      • With all six screws removed, lift up on the bridge to remove it from the body.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christopher Hartigan
164 İtibar
5 adet Kılavuz yazıldı
Ekip
Pasco Hernando, Team 5-3, Prince Fall 2014 Pasco Hernando, Team 5-3, Prince Fall 2014 üyesi
PHSC-PRINCE-F14S5G3
9 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 39
Her zaman: 3,106
