Ana içeriğe geç
Fender Starcaster Tuning Heads Replacement
Neye ihtiyacın var
    1. Fender Starcaster Tuning Heads Replacement, Loosen the Strings: adım 1, 3 resimden 1. Fender Starcaster Tuning Heads Replacement, Loosen the Strings: adım 1, 3 resimden 2. Fender Starcaster Tuning Heads Replacement, Loosen the Strings: adım 1, 3 resimden 3.
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
      FixBot'a Sor
      Yorum Ekle
    2. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: adım 2, 2 resimden 1. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: adım 2, 2 resimden 2.
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
      FixBot'a Sor
      Yorum Ekle
    3. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: adım 3, 3 resimden 1. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: adım 3, 3 resimden 2. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: adım 3, 3 resimden 3.
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
      FixBot'a Sor
      Yorum Ekle
    1. Fender Starcaster Tuning Heads Replacement, Tuning Heads: adım 4, 2 resimden 1. Fender Starcaster Tuning Heads Replacement, Tuning Heads: adım 4, 2 resimden 2.
      • Using a wrench, remove the nuts around each tuning head post.
      FixBot'a Sor
      Yorum Ekle
    2. Fender Starcaster Tuning Heads Replacement: adım 5, 3 resimden 1. Fender Starcaster Tuning Heads Replacement: adım 5, 3 resimden 2. Fender Starcaster Tuning Heads Replacement: adım 5, 3 resimden 3.
      • Next, remove the threaded retainer sleeve from each post.
      • Don't forget the washer.
      FixBot'a Sor
      Yorum Ekle
    3. Fender Starcaster Tuning Heads Replacement: adım 6, 2 resimden 1. Fender Starcaster Tuning Heads Replacement: adım 6, 2 resimden 2.
      • Next, remove the screws from the backside of each tuner.
      FixBot'a Sor
      Yorum Ekle
    4. Fender Starcaster Tuning Heads Replacement: adım 7, 2 resimden 1. Fender Starcaster Tuning Heads Replacement: adım 7, 2 resimden 2.
      • Finally, remove the tuning machine assembly from the headstock.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christopher Hartigan
164 İtibar
5 adet Kılavuz yazıldı
Ekip
Pasco Hernando, Team 5-3, Prince Fall 2014 Pasco Hernando, Team 5-3, Prince Fall 2014 üyesi
PHSC-PRINCE-F14S5G3
9 Üyeler
10 adet Kılavuz yazıldı
3Kılavuz Yorumları
Does the 2013 Starcaster take a 10mm tuning peg?
Brian Seese - Yanıt Paylaş
This is only the removal. Nothing After step 7. What about the actual replacement? What did you replace them with? Did it involve any machining?
Richard Caruso - Yanıt Paylaş
This is only the removal. What about the actual replacement? What did you replace them with? Did it involve any machining?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 3,409
