Giriş
If the tuners have broken, become excessively lose, or seized, they will require replacement.
Neye ihtiyacın var
Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
Repeat this for all six strings on the guitar.
It may be necessary to use pliers to remove string ends from the tuning peg.
After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
2 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Does the 2013 Starcaster take a 10mm tuning peg?
This is only the removal. Nothing After step 7. What about the actual replacement? What did you replace them with? Did it involve any machining?
This is only the removal. What about the actual replacement? What did you replace them with? Did it involve any machining?
