Ana içeriğe geç
Fiat 500 Abarth Taillight Replacement
Neye ihtiyacın var
  1. Fiat 500 Abarth Taillight Replacement, Fiat 500 Abarth Taillight: adım 1, 2 resimden 1. Fiat 500 Abarth Taillight Replacement, Fiat 500 Abarth Taillight: adım 1, 2 resimden 2.
    • Remove the two 10 mm bolts to the side of the taillight.
  2. Fiat 500 Abarth Taillight Replacement: adım 2, 2 resimden 1. Fiat 500 Abarth Taillight Replacement: adım 2, 2 resimden 2.
    • Using a pry tool or something flat, carefully get in-between the light and the car and pry the light off.
    • The light still has cable connections to the car body, so be sure not to rip these during removal.
  3. Fiat 500 Abarth Taillight Replacement: adım 3, 3 resimden 1. Fiat 500 Abarth Taillight Replacement: adım 3, 3 resimden 2. Fiat 500 Abarth Taillight Replacement: adım 3, 3 resimden 3.
    • There are several little clips on this module.
    • Unclip the clips on the back of the light and remove the panel.
  4. Fiat 500 Abarth Taillight Replacement: adım 4, 3 resimden 1. Fiat 500 Abarth Taillight Replacement: adım 4, 3 resimden 2. Fiat 500 Abarth Taillight Replacement: adım 4, 3 resimden 3.
    • Remove the burnt out bulb by pulling it out from the panel.
  5. Fiat 500 Abarth Taillight Replacement: adım 5, 3 resimden 1. Fiat 500 Abarth Taillight Replacement: adım 5, 3 resimden 2. Fiat 500 Abarth Taillight Replacement: adım 5, 3 resimden 3.
    • Clip the panel back onto the light and put it back into the frame of the car.
    • Replace the two bolts with a 10 mm socket.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 69
Son 30 gün: 331
Her zaman: 10,925
