Ana içeriğe geç
Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW
Neye ihtiyacın var
  1. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW, Filter Housing for GE Refrigerators: adım 1, 1 resimden 1.
    • Disconnect the electric plug from the wall.
  2. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: adım 2, 1 resimden 1.
    • Turn off or push down off water main valve from the wall.
  3. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: adım 3, 3 resimden 1. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: adım 3, 3 resimden 2. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: adım 3, 3 resimden 3.
    • Remove the back panel with 6 screws from the back panel using a 8 mm nut driver.
  4. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: adım 4, 2 resimden 1. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: adım 4, 2 resimden 2.
    • Disconnect the water supplied line from the refrigerator using two 13 mm open-end wrenches.
    • Use a little bucket to receive the water from the water lines.
  5. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: adım 5, 1 resimden 1.
    • Disconnect the water line from the water inlet valve using and open-end wrench size 15mm
  6. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: adım 6, 2 resimden 1. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: adım 6, 2 resimden 2.
    • Disconnect the water line cover removing 2 screws using a 7 mm nut driver.
    • Pull up the gum seal compound.
  7. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: adım 7, 1 resimden 1.
    • Push the left side of the filter cover and pull it straight out.
  8. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: adım 8, 2 resimden 1. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: adım 8, 2 resimden 2.
    • Remove the 2 screws on top of the housing using 7 mm nut driver.
    • Pull the housing and filter out slowly.
    • Remove the filter by turn it counterclockwise
Sonuç
Giancarlo Marruffo
2 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 2,090
