Ana içeriğe geç
First Alert Smoke Alarm 9120B Battery Replacement
Neye ihtiyacın var
  1. First Alert Smoke Alarm 9120B Battery Replacement, Battery: adım 1, 3 resimden 1. First Alert Smoke Alarm 9120B Battery Replacement, Battery: adım 1, 3 resimden 2. First Alert Smoke Alarm 9120B Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the alarm by rotating it counter clockwise in the mount.
    • The alarm should fall off once rotated enough. The cable should be the only thing holding it in place if done correctly.
  2. First Alert Smoke Alarm 9120B Battery Replacement: adım 2, 2 resimden 1. First Alert Smoke Alarm 9120B Battery Replacement: adım 2, 2 resimden 2.
    • Unplug the cable from the alarm.
  3. First Alert Smoke Alarm 9120B Battery Replacement: adım 3, 3 resimden 1. First Alert Smoke Alarm 9120B Battery Replacement: adım 3, 3 resimden 2. First Alert Smoke Alarm 9120B Battery Replacement: adım 3, 3 resimden 3.
    • Press down on the catch on the top left of the alarm to open the battery compartment.
  4. First Alert Smoke Alarm 9120B Battery Replacement: adım 4, 2 resimden 1. First Alert Smoke Alarm 9120B Battery Replacement: adım 4, 2 resimden 2.
    • Remove the battery and dispose of it properly.
    • Replace the old battery with a new 9V battery and close the compartment.
    • You should hear a click to know that the compartment is secured.
  5. First Alert Smoke Alarm 9120B Battery Replacement: adım 5, 2 resimden 1. First Alert Smoke Alarm 9120B Battery Replacement: adım 5, 2 resimden 2.
    • Line up the holes of the cable on the mount with the pins on the alarm.
    • Reconnect the cable on the mount to that on the alarm.
    • It should insert itself with minimal force.
  6. First Alert Smoke Alarm 9120B Battery Replacement: adım 6, 2 resimden 1. First Alert Smoke Alarm 9120B Battery Replacement: adım 6, 2 resimden 2.
    • Press the alarm into the mount.
  7. First Alert Smoke Alarm 9120B Battery Replacement: adım 7, 3 resimden 1. First Alert Smoke Alarm 9120B Battery Replacement: adım 7, 3 resimden 2. First Alert Smoke Alarm 9120B Battery Replacement: adım 7, 3 resimden 3.
    • Rotate the alarm clockwise until it does not turn anymore. This makes sure the alarm is secured.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Miggy Reyes
219 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team S3-G17, Cowan Spring 2021 Texas Tech, Team S3-G17, Cowan Spring 2021 üyesi
TTU-COWAN-S21S3G17
1 Üye
3 adet Kılavuz yazıldı
5 Yorum
How do I disconnect the cable? Seems very tight and cannot disconnect.
Jeanne O - Yanıt
This is related to first alert smoke alarm 9120B. Can not remove connecting cable from alarm. Is very tight. So unable to change battery. Any suggestions?
Jeanne O - Yanıt
These alarms suck! Pressing the tab and the battery compartment does NOT pop open. I needed a knife to pry it open, and then it had to be forced close. NOT user error! The plastic pins that hold the battery compartment closed don't move out of the way enough to allow opening.
James Durso - Yanıt
I replaced the battery and it is still beeping, reset the smoke alarm. What should I do now?
Donald Sandford - Yanıt
Buy and install a new alarm. It’s easier than trying to fix on.
Stephen Taylor - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 28
Son 7 gün: 236
Son 30 gün: 1,085
Her zaman: 31,223
