Ana içeriğe geç
Fitbit Alta HR Battery Replacement
Neye ihtiyacın var
  1. Fitbit Alta HR Battery Replacement, Remove straps: adım 1, 2 resimden 1. Fitbit Alta HR Battery Replacement, Remove straps: adım 1, 2 resimden 2.
    • Push in the clip and slide off the strap from each side.
  2. Fitbit Alta HR Battery Replacement, Remove front cover: adım 2, 1 resimden 1.
    • Use a spudger to remove the front cover.
  3. Fitbit Alta HR Battery Replacement, Lift display: adım 3, 1 resimden 1.
    • Use a spudger to lift the display.
  4. Fitbit Alta HR Battery Replacement, Disconnect heart rate monitor: adım 4, 1 resimden 1.
    • Use a spudger to disconnect the cable that connects the heart rate monitor to the motherboard.
  5. Fitbit Alta HR Battery Replacement, Remove screws from motherboard: adım 5, 1 resimden 1.
    • Use a hex 0.7 screwdriver to remove the screws from the motherboard.
  6. Fitbit Alta HR Battery Replacement, Lift motherboard: adım 6, 2 resimden 1. Fitbit Alta HR Battery Replacement, Lift motherboard: adım 6, 2 resimden 2.
    • Use a spudger to lift the motherboard.
  7. Fitbit Alta HR Battery Replacement, Lift battery and remove innards: adım 7, 1 resimden 1.
    • Use a spudger to lift the battery.
    • When the battery is lifted, the connected components (display, motherboard, battery) will come out.
    • Use a soldering iron to desolder the two battery contacts from the motherboard.
    • Ensure positive and negative wires are in the correct positions. There are + and – signs on the motherboard. Red is positive. Black is negative.
    • Use a soldering iron and lead-free solder to solder the new battery to the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Wendy Sato
259 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 60
Her zaman: 2,592
