Ana içeriğe geç
Fitbit Blaze Display Frame Replacement
Neye ihtiyacın var
  1. Fitbit Blaze Display Frame Replacement, Wristband: adım 1, 2 resimden 1. Fitbit Blaze Display Frame Replacement, Wristband: adım 1, 2 resimden 2.
    • Locate the front LCD screen on your device.
    • Fitbit logo should appear in the bottom center of the screen.
    FixBot'a Sor
    Yorum Ekle
  2. Fitbit Blaze Display Frame Replacement: adım 2, 1 resimden 1.
    • Push the screen out through the back of the metal ring enclosure.
    • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
    FixBot'a Sor
    Yorum Ekle
  3. Fitbit Blaze Display Frame Replacement: adım 3, 3 resimden 1. Fitbit Blaze Display Frame Replacement: adım 3, 3 resimden 2. Fitbit Blaze Display Frame Replacement: adım 3, 3 resimden 3.
    • Locate the metal pin behind the wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
    • Use a small amount of force to avoid damaging the pins.
    • Remove wristband.
    FixBot'a Sor
    Yorum Ekle
  4. Fitbit Blaze Display Frame Replacement, Display Frame: adım 4, 3 resimden 1. Fitbit Blaze Display Frame Replacement, Display Frame: adım 4, 3 resimden 2. Fitbit Blaze Display Frame Replacement, Display Frame: adım 4, 3 resimden 3.
    • Locate the pin behind the second wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into opposite direction.
    • Remove wristband.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Adrian Borrego
2.242 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G3, Sullivan Spring 2017 USF Tampa, Team S3-G3, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S3G3
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 11,449
