Ana içeriğe geç
Fitbit Charge HR Screen Replacement
Neye ihtiyacın var
  1. Fitbit Charge HR Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Screen Replacement: adım 2, 3 resimden 1. Fitbit Charge HR Screen Replacement: adım 2, 3 resimden 2. Fitbit Charge HR Screen Replacement: adım 2, 3 resimden 3.
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Screen Replacement: adım 3, 2 resimden 1. Fitbit Charge HR Screen Replacement: adım 3, 2 resimden 2.
    • Remove the motherboard assembly from the device.
    • Flip the motherboard over so the screen is facing upwards.
  4. Fitbit Charge HR Screen Replacement: adım 4, 3 resimden 1. Fitbit Charge HR Screen Replacement: adım 4, 3 resimden 2. Fitbit Charge HR Screen Replacement: adım 4, 3 resimden 3.
    • Wedge a nylon spudger between the screen and the motherboard.
    • Gently pry the screen up and remove it from the motherboard.
    • Metal spudgers can puncture an unprotected battery and damage components like the motherboard. Always choose a tool that's ESD-safe, such as a nylon spudger or plastic opening tool.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 886
