Ana içeriğe geç
Fitbit Charge HR Vibration Motor Replacement
Neye ihtiyacın var
  1. Fitbit Charge HR Vibration Motor Replacement, Vibration Motor: adım 1, 1 resimden 1.
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Vibration Motor Replacement: adım 2, 3 resimden 1. Fitbit Charge HR Vibration Motor Replacement: adım 2, 3 resimden 2. Fitbit Charge HR Vibration Motor Replacement: adım 2, 3 resimden 3.
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Vibration Motor Replacement: adım 3, 1 resimden 1.
    • Remove the motherboard assembly from the device by gently lifting.
  4. Fitbit Charge HR Vibration Motor Replacement: adım 4, 2 resimden 1. Fitbit Charge HR Vibration Motor Replacement: adım 4, 2 resimden 2.
    • Locate the vibration motor on the motherboard.
    • Desolder the red and black wires connected to the motherboard from the vibration motor.
    • Red wire is located closer to the outside. Black wire is closer to the inside of the motherboard.
    • Replace with new vibration motor.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 493
