Ana içeriğe geç
Fitbit Inspire 2 Wrist Straps Replacement
Neye ihtiyacın var
  1. Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: adım 1, 3 resimden 1. Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: adım 1, 3 resimden 2. Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: adım 1, 3 resimden 3.
    • Use a spudger or your fingernail to push back the release lever on one of the two straps on the underside of the Fitbit.
    • You may experience some resistance from the release, but don't use excessive force, as it may damage the release levers.
  2. Fitbit Inspire 2 Wrist Straps Replacement: adım 2, 3 resimden 1. Fitbit Inspire 2 Wrist Straps Replacement: adım 2, 3 resimden 2. Fitbit Inspire 2 Wrist Straps Replacement: adım 2, 3 resimden 3.
    • As you pull back the release lever, shift the strap diagonally.
    • Remove from the Fitbit strap.
    • Repeat the process for the other strap.
  3. Fitbit Inspire 2 Wrist Straps Replacement: adım 3, 2 resimden 1. Fitbit Inspire 2 Wrist Straps Replacement: adım 3, 2 resimden 2.
    • Now that the old straps are detached from the Fitbit, take the opportunity to clean the watch and strap connection points.
    • Use a spudger to clean the inside of the strap chamber. Scrape out any residue or grime that may have built up over the past months or years.
  4. Fitbit Inspire 2 Wrist Straps Replacement: adım 4, 1 resimden 1.
    • Slide the replacement straps into the given slot and the lever will click back into place.
  5. Fitbit Inspire 2 Wrist Straps Replacement: adım 5, 2 resimden 1. Fitbit Inspire 2 Wrist Straps Replacement: adım 5, 2 resimden 2.
    • The straps should be secure and you can wear your watch again!
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
MarcSerpa
142 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 308
