Giriş
Is your Fitbit Surge battery not charging no matter what you do? Read this guide to learn how to replace the battery, but keep in mind that you will need to cut the wristband in order to complete this repair and the band cannot be reattached.
Neye ihtiyacın var
Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
To reassemble your device, follow these instructions in reverse order. Keep in mind that the band will need to be cut for this repair and it cannot be reattached.
11 farklı kişi bu kılavuzu tamamladı.
10Kılavuz Yorumları
I'm about to embark on replacing the battery for my fitbit surge. After having it for over 2 years it requires a charge about twice a day which get annoying.
Does removing/replacing the battery require the moderate soldering skill?
Looks like it must.
The last photo I think shows the tool prying the force feedback motor, the battery is the white plastic covered slim brick on the top right.
You do not need to cut bands off
The replacement battery for the Fitbit Surge can be found here:
It also includes all of the tools (except soldering iron) needed for the repair.
